header questions
Old Feb 21, 2009 | 03:27 AM
1989_RALLYSPORT's Avatar
Default header questions
ok are the header bolt paterns the same between 305 heads and most 350 heads?
i want headers for my car now but ill eventually swap to a 350
and what are the cheapest headers as im not going for looks just performance and sound
also are there any low profile mufflers as i want to run duals that end in front of the rear tires probably 3 in pipe
would there be clearance issues using cherrybomb glasspacks?
Old Feb 21, 2009 | 08:16 AM
Jr. Mechanic's Avatar
August 2009 ROTM
Yes.
Jegs headers: http://www.jegs.com/i/JEGS/555/30053/10002/-1
Tons of clearance issues, stick with a 3" single pipe with a 3" cross flow muffler.
Search.
Old Feb 24, 2009 | 12:16 AM
what clearance issues will i have other than the ac box thing?
i was thinking about taking that out and closing it up with sheet metal. i haven't found any kit to do it and make it look clean though.
Old Feb 24, 2009 | 09:33 AM
age84's Avatar
March '09 ROTM
I have a set of headman headers on mine in order to remove them the only thing i needed to do is remove my valve covers and oil dipstick
http://s519.photobucket.com/albums/u...t=SS850333.jpg
well i guess you would also have to deal with the A/C lines also
Old Feb 24, 2009 | 11:06 AM
August 2009 ROTM
No clearance issues with the headers, unless you go long tubes. The dual exhaust is where you run into clearance issues.
Old Feb 25, 2009 | 07:27 AM
djs383's Avatar
What are guys doing about emission lines and all that other junk?
Old Feb 25, 2009 | 10:08 AM
August 2009 ROTM
Don't see emissions mentioned anywhere here...?
Old Feb 25, 2009 | 12:00 PM
bobarian91's Avatar
BackseatBob
Emissions? who needs emissions? in NM they don't have a smog test or anything like that so I can do whatever I want wtih my car/truck.
Yep, 305 headers will fit on a 350. Anything up to vortecs have the same bolt pattern...
Glasspacks will fit, or should, but they are going to give you a LOT of annoying
resonance inside the car. My truck with straight pipes gives me less interior noise than it did with glasspacks.
if you want to spend a little bit more $$ on mufflers, give these guys a shot... http://www.jegs.com/p/Cherry+Bomb/767133/10002/-1 they are wider but pretty short.
or try these, I hear good things about these guys...http://www.jegs.com/p/Car+Chemistry/752539/10002/-1
they have a cheaper weld/rivet in version as well...
Old Feb 25, 2009 | 05:01 PM
yeah i was looking at that wide cherrybomb thats more or less the style i was going to use with duals but with single out instead of dual output
hell my stock exhaust as it sits now sits nearly 2-3 inches from the undercarriage so why would there be clearance issues with duals?
im not running them over the axle just in front of the rear tires
Old Feb 25, 2009 | 05:06 PM
bobarian91's Avatar
BackseatBob
You should be fine. You COULD run side-pipes and go with a more custom look.... but they'd have to be custom made methinks.
You should be good to go, the headers will fit, the exhaust will fit... all that's left now is to get to work! and don't forget to give us a sound clip when ur done!
