header question
Old 02-25-2007, 11:38 AM
92camaroRS's Avatar
Default header question
I was going to get some headers and a new y pipe for the car. The're eldelbrock, ceramic, accept all stock emissions equiptment, no welding required, and they are $399. My question is if i pull off everything including the air cleaner, tbi, intake manifold, valve covers, all the hoses that run over the valve covers, and the fuel rails; will I be able to get those headers in? Thanks.
Old 02-25-2007, 02:47 PM
ajk511's Avatar
Default RE: header question
it will be WAYYYYY easier to go in from the bottom. or if you can unhook your motor mounts and jack up the engine just a little bit.
Old 02-25-2007, 06:27 PM
MadMikeZ28's Avatar
They are not full length headers. They will go through the top and are not to much a pain.
Old 02-25-2007, 09:50 PM
350rs's Avatar
March 2008 ROTM
just talkin from experience here... i have a set of hooker super comp shorty headers on my 89 rs. in order to put in the passenger side header, i undid the motor mount bold and jacked that side of the engine up a bit. 2 or 3 inches max. Just as AJK states. But i had to remove the air pump. Then i slid the header in from below. after that i replaced the motor mount bolt and went on with the drivers side since there is almost nothing over there, i just put it in from the top.the bolt closest to the firewall is a real problem to get in, took me awhile to get it in and tighten it.
Old 02-25-2007, 11:15 PM
ajk511's Avatar
350RS i think i actually got that tip from you when i had to replace my exhaust gasket on the passenger side
Old 02-26-2007, 12:27 AM
microkid's Avatar
March 2011 ROTM
Technical User
im gonna be replacing my manifolds with headers soon as well. im looking at the cheap hedman headers. do i have to get a bung welded in for the 02 sensors for the tpi? i can prolly get a shop to do it for me. also, what else will i need besides gaskets and bolts?
Old 02-26-2007, 12:35 AM
350rs's Avatar
March 2008 ROTM
lol yea you prolly did. i like to share my experiences with my car with people who need the help.
BIGMIKE
08-31-2007 06:12 PM
1bad96Z28
04-26-2007 02:30 AM
kyleb
01-31-2007 12:25 AM
RedDragon
11-14-2006 07:15 PM
frankthetank078
04-04-2006 10:35 PM
Quick Reply: header question
