header gasket and bolt kit
Old 04-19-2007, 12:19 AM
microkid's Avatar
March 2011 ROTM
Technical User
Default header gasket and bolt kit
lookin for a header gasket and bolt kit for my 86 305 tpi. theres many different styles out there, and i dont know which to get for mine. im bolting on a set of hedman headers. also, lookin for an o2 sensor bung as well.
Old 05-07-2007, 11:29 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: header gasket and bolt kit
any type will really work. just choose the best gasket you can find, the bolts are pretty much all the same
Old 05-08-2007, 12:27 AM
350rs's Avatar
March 2008 ROTM
ive been thinking about a copper gasket... any idea on if those work better or worse than the paper ones? mine now SUCK
Old 05-08-2007, 12:45 AM
1985RS's Avatar
copper is the way to go for sure, as for the bolts, if you just get regular ones, they tend to back off, and you have to tighten them up every so often, so maybe check around for a set of header bolts with locks so they dont back out.
Old 05-08-2007, 01:25 AM
vampyrico's Avatar
a dab of clear loc tite should hold all the bolts untill you want to take them off. we use them on aircraft engines for applications that are prone to vibration and heat. which is pretty much everything on the engine, recip or turbine.
Old 05-08-2007, 05:58 PM
microkid's Avatar
March 2011 ROTM
Technical User
i was looking at the copper gaskets, and the losking bolts. do you guys know what size the bolts are? its a perimeter style valve cover, iron head
Old 05-09-2007, 01:24 AM
1985RS's Avatar
just go into any auto parts store and ask for a set of header bolts for a 305, they should have them in stock for fairly cheap
Old 05-15-2007, 04:20 PM
microkid's Avatar
March 2011 ROTM
Technical User
what style gaskets should i get, the sb square port style? i have part number from jegs for the one im looking at, 720-7151 its from mr. gasket
Old 05-15-2007, 05:06 PM
74454bb's Avatar
May 2007 ROTM
it depends on the ports on the heads, not sure how the small block heads go but they may be round or square, run the #'s for your heads.
Old 05-15-2007, 05:09 PM
microkid's Avatar
March 2011 ROTM
Technical User
theres no legible numbers on the head. based on the shape of the manifold on there, im gonna go with square
Quick Reply: header gasket and bolt kit
