head advice
Old Aug 24, 2008 | 05:29 PM
slick84z28's Avatar
Default head advice
what would be better set of heads for a 355.motor has flat top pistons with the 4 valve relieves.the motor has a set of 993 cast 194/150 valves,ported andpolished and shaved on it now.i also a set of HO305 heads i was going to use on another motor.they are 416 cast,shaved .10,intake drilled to .194 .150 exh manley budget valves,ported and polished.the 993s is a 76cc and the 416s is 58 or 62cc.all of my sources are saying two diffferent cc chambers for the 416 (305)heads. i know if i go to the smaller cc heads i would get more compression. it will probably put me where i need to mix my gas.the only reason why i was thinking of doing this is because i already have the other heads. i do not know if the intake runners are going to hurt the air flow on the 416s vs the 993s even if they are ported? any advise would be helpful. thanks
Old Aug 24, 2008 | 10:56 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Default RE: head advice
I would go with the double hump 305 heads, should give you a bit of a power boost.
sohcnick
Mar 25, 2013 04:03 PM
fasttony350
Feb 8, 2011 05:08 PM
RatCamaro
Jan 2, 2011 01:58 PM
raysean22589
Feb 2, 2010 08:22 PM
1981camaroz28
Oct 23, 2007 05:44 PM
