got a question about a 400 turbo tranny
Old Oct 19, 2006 | 07:17 PM
1983camaro's Avatar
Default got a question about a 400 turbo tranny
i know i posted this in the classics forum but i figured i'd get an answer quicker on here because theres more traffic here but : in a month when i have the money saved up , im buying a 1979 camaro project car off a person i know for 850.00 . he had a v8 in it which seized on him due to sitting, the transmission which is a 400 turbo transmission has been rebuilt, but hasnt been installed for a while he said ( didnt exactly say how long). my question is: How long can a rebuilt transmission sit without being installed and ran before it needs rebuilt again?
Old Oct 19, 2006 | 07:30 PM
350DREAMS's Avatar
Default RE: got a question about a 400 turbo tranny
bro he lied to u,. a motor wont just seize for no reason my dad and i have a 8second ss nova. we baught it off a junk it was sitting at for ((10YEARS)) and still got it started to get it home to re-build. so to answer ur question if something it built CORRECTLY it will not just seaze. so if it was done right it should be fine.
Old Oct 19, 2006 | 07:33 PM
1983camaro's Avatar
well he didnt really say it seized, thats just the word i used at the time cause i couldnt come up with any thing else. but it did sit for a long time and he pulled the motor to rebuild it but after he pulled the motor and tranny, he had other priorities and put the camaro to the back burner.
Old Oct 19, 2006 | 07:42 PM
SickSickSick's Avatar
bullcrap ... rust buildup on the cylinders walls of a tight motor can keep it from turning over i assure you. for lack of better words the motor would be siezed. Sick
Old Oct 19, 2006 | 07:53 PM
350DREAMS's Avatar
he said the motor was just re-built can uexplain what liquid was in it to cause rust?
Old Oct 19, 2006 | 08:06 PM
no spark plugs would cause cylinder rust as well was open valves. condensation builds up on metal surfaces during temperature changes. humid areas can be especially troublesome to an engine that sets up for extended periods of time. Sick
Old Oct 19, 2006 | 08:17 PM
350DREAMS's Avatar
true depends where it was stored aswell.
Old Oct 20, 2006 | 12:01 AM
Flyin89's Avatar
he didnt say the motor was rebuilt, jus the tranny.
if the tranny was built right and kept some where safe and out of weather and all that junk you should be good. Jus make sure its got a filter and what not.
Old Oct 20, 2006 | 05:26 AM
uncle bill's Avatar
The only way to know for sure is to tear it down. You'll find out then. The 400 turbo should be plugged if it's a fresh rebuild so it could sit for a long while.
Comanro
Jul 21, 2014 11:36 AM
camaro maniac
Aug 14, 2007 08:45 PM
1983camaro
Oct 19, 2006 07:38 PM
freekstylejimmy
Feb 20, 2006 02:49 PM
