got a problem with my 91 RS
Old May 11, 2010 | 08:11 PM
john91rs's Avatar
Default got a problem with my 91 RS
i woke up today got in my camaro and i noticed when i opened the door no lights turned on and my power lock buttons dont work. but my power windows work fine. i thought it was a fuse so i checked them saw a few missing. does anyone have a pic of there fuse box i can compare mine to? or do you think it's a different problem in the wiring. i bought the car a month or so ago and the lights and locks worked fine. please let me know what you think it could be.
Old May 11, 2010 | 08:47 PM
kandied91z's Avatar
been years since i've had issue with a fuse box. when i bought my car used in 98 the dealer said it was an electrical issue. just needed to replace a fuse. just check the fuses in the box, replace what's necessary and the relays last if needed. they are swapable. if some are missing obviously its an issue. look up thirdgen fuse schematics and you should see what you need.
www.thirdgen.org is a good source for that. good luck.
Old May 12, 2010 | 08:08 PM
skidoodave's Avatar
Check Acc fuse. It controls interior lights, power locks and mirrors, rear power hatch, horn and cig lighter. These cars are known for the cig lighter shorting out and blowing the fuse. Replace the 20 amp Acc fuse and pull out the lighter from the socket and you should have no more issues. Don't plug your phone in either or you'll pop the fuse again most likely
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
