Gears
I Have a 1989 with a 400smb and a turbo 350 tranny. I would like to put a shift kit and dont really know what brand i should lean towards. and i would like to change the gears in the rear end but im new to all this. So could anybody show me the right direction to go.
hey man i have a 91 with a built 350 and a th-350 and 3.73 gears. and since its a street car if i had 4.11 gears i would very very unhappy. go with 3.73 gears and B&M shift kit.if you go 4.11 you will being doing damn near 4000rpm at 50mph, for being a street car i almost want a 3.23 gear but im planning on a built 700-r4 trans and keeping the 3.73 gears
Im running 3.73's with a 3 speed and I run 3k on the highway. 4.11's are just not a gear to use if you plan on doing anything more than driving down the street to get ice cream.
My rear gears are the ONLY job I farmed out to a local shop. (went from highway 2.77's to street 3.73's) You need a few special tools and failure to procure and use them will most likely end up in you fragging your read end in a few hours. Im assuming when Black says its no big deal hes either yanking your chain or hes got all the tools.....
A 400 SB with 3.73's will be SICK!
