Gauge Cluster Swap
RE: Gauge Cluster Swap
Well you got the cluster and I think you are going to be the first to find out. I really do not think it will fit because of the slight differences. Also the 90-92 speedos' are electric and I would imagine all the prior years are cable.
The fuel gauge, along with all the others, are a different shapein the 90-92s'. But if you were to remove your fuel gauge they are either just pushed into some clips so you can just pull the face and screen and screws and pull it out without removing the cluster
OR
They have nuts on the back side. I have messed with Camaro and S10 clusters recently and I might be mixing the two up.
OR
