Fuel pump recommended?
Old Mar 25, 2025 | 02:38 PM
Shoebox55's Avatar
Default Fuel pump recommended?
My car stalls out at random and it’s getting worse. I tested the fuel pump pressure 39 psi and it was fine. Held steady even after key was off. I’m fourth to fortieth owner? I have no idea. Just changed the Ignition control module, made no difference. Considering the age of the pump and filter, I have no confidence in them. At this point I’m willing to change them; I’m okay with a shotgun remove and replace approach.
My car is a 55 Chevy with a 305TPI engine. I believe the donor car was a 3rd gen Camaro; base, Z28, IROC? Again, I don’t know. My fuel pump is in tank and I need around 40psi for my injectors. Any good vendors I should consider, conversely bad one to avoid? Personal experience with a vendor to suggest would be appreciated, a PN would be awesome. Thank you for your time.
Frank
cantdrive55
Sep 7, 2013 10:12 PM
poi551
Feb 23, 2011 10:25 AM
nehidustin
Jun 28, 2010 07:30 PM
pop164
Sep 5, 2008 12:38 PM
