fuel problem HELP!!
![Exclamation](https://camaroforums.com/forum/images/icons/icon4.gif)
well i have a 91 camaro rs and its not getting gas to the engine and i cant figure out why. it used to be a v6 manual and i swapped it with a v8 350 and its now auto. the fuel pump is working so i don't know what it is. if you got any idea please let me know. thanks!
Its carberated. And I hooked the line to the pump and started the car and it runs fine like that. I'm thinking it might have something to do with the old fuel pump in the gas tank could that cause this problem?
However, if you're running a mechanical fuel pump, trying to draw the gas through the (now dead) in-tank pump is going to be a big restriction.
