Front end assembly instructions?
Old Mar 26, 2008 | 07:24 PM
dantheman912's Avatar
Default Front end assembly instructions?
I redid the front assembly because it was crashed on a 92 camaro rs, and i mostly remember where everything goes, but all the plasti pieces....not so much. Is there a site or a book that i can buy that shows me step by step processes for this?
Also, the drivers side window goes up only for 5 seconds at a time, and then just stops, but it will go down. My battery is fully charged..What else can it be? the window motor itself? And to that, my door locks wont unlock and lock all the way like they should. How do i fix both?!!??
Old Mar 26, 2008 | 07:34 PM
350rs's Avatar
March 2008 ROTM
Default RE: Front end assembly instructions?
the locks have worn out. most likely just replace the part and it will work again. also it could be the whole motor for the lock.
Old Mar 26, 2008 | 07:54 PM
what do you mean, just replace the locks themselves?
and if not that, then theres only one lock motor to replace?
Old Mar 28, 2008 | 08:25 PM
MadMikeZ28's Avatar
No instructions that I know of to look at for reassembly...Except maybe a factory service manual. Just start bolting stuff together. You'll figure it out.
Try swapping the switches from the drivers and passenger side. First easy thing to do. Also look on the fuse panel for two small silver boxes. Those would be breakers for the power windows. Up draws more current because its working against gravity.
My drivers door power lock does not unlock all the way either. Push the button 2-3 times and its full unlock. When the door panel is all apart though it unlocks fine. Something about the door panel may be a little warped and causing the rod that goes behind it to bind/drag
danny
Apr 17, 2011 09:38 PM
kats69
Aug 29, 2010 12:52 PM
MS69 YENKO/4-SPEED
Jun 17, 2010 03:01 PM
speedcoder
Sep 17, 2007 02:15 AM
bakedog31
Jun 14, 2005 10:57 PM
