found a 87 iroc
Old Jan 23, 2021 | 11:42 PM
Scott Hopkins's Avatar
Default found a 87 iroc
found a 87 iroc z with 350 and t tops. ohio car withsome rust. Owner said it runs but needs repair. Hes offered it to me for 1700 sounds cheap but im a first gen owner so.....lol. What should i look for in problems with this car??? Maybe 1700 is to high any thoughts are greatly appreciated.
thanks in advance
scott h
Old Jan 24, 2021 | 10:30 AM
Well the 350 version of the Iroc is the best 3rd gen IMO. Is it a T-top car? T-tops leak and they car rust out the floors and like a first gen it can spread to the frame rails. You really want to understand the rust and get an idea on what it will take to fix it right. Unlike a first gen the cost of getting a high miles rust damaged back to a solid, dependable, nice looking car and easily exceed the value of the car. By todays standards its not going to be a fast car. There are some known issues like the rear frame rails and the intake gasket but on a but on a 35 year old car how the car has been maintained will determine value. Heck if its a cheery low miles 87 and the only thing is wrong is it need floors and frame rails I would be all over that. Same car that is all worn out and had poor maintenance may be a parts car not worth saving.
After saying all that I would be temped at $1700 if we where just talking floors and the engine/trans seemed good enough to last awhile. But also keep in mind depending on your skill level you could buy a V6 and for an LS swap and hit 400 hp and 24 MPG.
Old Jan 24, 2021 | 10:35 AM
Prices are all over the map (literally prices vary a lot depending on location) on 3rd gens but that sounds pretty fair if it runs and isn't a total rust bucket.
The late IROC Z with the factory 350 is the most desireable of the 3rd gen cars,do you know if it's a numbers matching original car?
https://www.nadaguides.com/Cars/1987...t-Coupe/Values
Post up pics!
carkid'69
82-92 V8 Tech
Sep 2, 2009 09:17 AM
Derek87IrocZ
82-92 V8 Tech
Mar 13, 2009 06:38 AM
GRIFF
Jan 8, 2008 05:41 PM
Whitetiger
82-92 V8 Tech
Jan 7, 2008 10:37 PM
oonighttrain
Mar 29, 2007 02:42 PM
