FLOODED ENGINE!
Old 09-05-2007 | 08:20 AM
Gordon24Camaro's Avatar
Default FLOODED ENGINE!
I have competly flooded my engine after replacing the starter, you can smell the gas from half a block away. Dont know what to do any help will be great
Engine- 89 305 tbi
[/align]
Old 09-05-2007 | 01:12 PM
Default RE: FLOODED ENGINE!
Find out why it is flooding and change the oil to get the gas out. Changing the starter is not going to cause the engine to flood. Beside the smell what makes you think it is flooded? Does it start & run?
Old 09-05-2007 | 04:21 PM
84 z .....'s Avatar
if u flooded the **** out of it u must let is avaporiot, just pull the plugs and wait , replace ur plugs if u areatty havent
[align=left] [/align]
Old 09-06-2007 | 10:22 AM
well after many hours of doing this an that i figured out that you have to floor the gas pedaland crank it, i guess thatshuts off the fuel pump regulator or sometihing and cause theres already gas in the engine itcranked, thing is i left the pedal to the floor allittle too long and redlined it BIG time, but its running fine, might have lost a little power so this weekend im gonna change the plugs and wires.
[/align]
Old 09-07-2007 | 08:44 PM
ScottD's Avatar
CHANGE YOUR OIL! If your oil smells that bad, it is fuel contaminated. This will thin the hell out of your oil and wreak havoc internally.
reddmotorhead
82-92 V6 Tech
05-30-2011 11:50 PM
carcrazycorey1
09-06-2010 06:24 PM
martynlutherking
05-25-2010 11:12 PM
Chevykicksbut
10-28-2009 07:14 AM
dnulnarts
07-06-2008 03:35 PM
Quick Reply: FLOODED ENGINE!
