Failing emissions...need help.
Ok here's the story...
I own a 1990 RS 305 TBI automatic with 237,700mi on the original engine. I pass all of the safety and high speed emissions but I fail the low speed HC and CO/CO2 emissions. I've changed the distributor, plugs, wires, cleaned out the intake, running 93 octane gas, and it has fresh oil in it--so does anyone know WHY I'm failing and HOW to fix it? I do have some blow-by (bad ring(s) or valve seal(s) hah or both) but the car has passed emissions with this problem for 90k-100k miles already. I'm at a loss on how to fix the problem without resorting to a rebuild or new engine. I don't have the cash yet for a new engine. If needed I can provide the exact numbers of my 2 emissions tests.
Any help is greatly appreciated.
A new cat, new plugs, O2 sensor,& heavier grade oil to cut down onoil burningmay help. Also make sure there are no leaks in the exhaust system, or it won't pass the CO2 test.
ORIGINAL: z28pete
A new cat, new plugs, O2 sensor, & heavier grade oil to cut down on oil burning may help. Also make sure there are no leaks in the exhaust system, or it won't pass the CO2 test.
![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
ORIGINAL: 91camaro305rs
Maybe a new cat and or muffler? How are the emmission laws Germany?
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
ORIGINAL: BlitzKrieg
I actually live in Texas, I'm just from Germany.
ORIGINAL: MadMikeZ28
Has any one noticed that new GM and others have thier parts manufactured in China? I was told it was China, Texas. Is that any where near Germany, Texas
The cat is not that old. Hold off on it. The egr is on the right , rear of the intake manifold. Near the distributer. The O2 is in the exhaust manifold on the left side near the #5 plug
Do you know of a guide with pics for replacing the EGR valve? I haven't replaced one of those yet so my experience is limited--actually its zero. lol
I've replaced the PCV valve and put a breather inplace of the rubber tube from the valve covers to the intake pan. I can't believe how stupid Chevy is for the way this engine is setup...or is it the fault of the US Goverment for the emissions bullsh*t? From the smog pump to the idiotic way the air intake is setup...its just mindblowingly redundant.
