Engine Rattling...ehh
Old Jan 21, 2009 | 10:20 AM
hurley870's Avatar
Default Engine Rattling...ehh
please read: I need help lol
Well it's been extremely cold here as of late, and my Camaro dosen't seem to like it anymore than I do. Ever since temps started dropping to the 20s and lower, my engine makes this rattling noise after I push the clutch in. It's hard to explain without being there in person but I will try my best in hopes someone can help me.
Very cold out - Start my car - Pull out of the driveway - Come to the first stoplight about a block down - As I prepare to stop, I push the brake and disengage the clutch. - RPM's rise to about 1500 since the engine is trying to warm up and the clutch is now disengaged.
RIGHT NOW is when the rattling occurs. It's very noticeable and sounds almost like an old diesel engine. It goes away for the most part when the engine is pulling the car, and I have yet to hear it once the engine is running at normal operating temperature. I'm already struggling to get this thing inspected without this problem, so any help is appreciated.
Thanks
Old Jan 21, 2009 | 10:48 AM
If the car is carbed, The increase in RPM is normal for a cold engine. If the car is injected the increse in RPM is not normal, and the IAC valve may not be working properly or the ECT may have drifted. The rattling is probably due to lack of lube when the engine is cold. I don't know what viscosity oil you are using, but for 20 deg temps, 5W30 is a good choice.
Old Jan 21, 2009 | 11:15 AM
age84's Avatar
March '09 ROTM
Where is the noise coming from? from the engine compartment is it high, low, left or right. is the engine bay stock?
Old Jan 21, 2009 | 01:52 PM
rockin85's Avatar
if your clutch feels different or any trouble shifting, the rattle might be from the throw out bearing. and as for the idle, if its carbed your choke might be stuck.
Old Jan 21, 2009 | 10:27 PM
91_Camaro_RS's Avatar
Whhaat? My car (tbi) has always gone up to like 2000 on cold mornings before its warmed up, your saying there is something wrong with this? Oh yeah and sorry for the attempted thread jacking.
Old Jan 21, 2009 | 11:10 PM
Lithorian's Avatar
yea my TBI 305 does the same, then comes down once warm.
Old Jan 21, 2009 | 11:36 PM
hurley870's Avatar
Well it's a 305 TBI L03 motor. Clutch feels normal. The rattling noise is relatively loud and noticable. I have not yet been out of the car to listen to the noise so I am not sure exactly from where in the engine bay it's coming from. Yes it is 100% stock under the hood, minus an air filter. Thanks everyone for the help so far.
imcdowel
May 18, 2010 12:03 AM
1stZ28Guy
LS Series Tech
Dec 8, 2009 12:05 AM
alma_mort
Mar 7, 2007 11:21 PM
ILYA
Jan 27, 2007 03:14 PM
Z28man
Apr 17, 2006 03:44 PM
