Engine idle problems
Hey guys,
I need help. Recently when I start my car, it will idle high and stay that way for up to 30 minutes. Around 2500 rpms... This "problem" only happens about every 5 times I go to start my car (sometimes it will idle fine, but others it just stays reved). It idles high in both park and in gear, and driving the car does not help the condition. Really have no lead on the problem yet, any advice would be appreciated.
Thanks
Thanks
you may have done this already but check to make sure the throttle is not sticking. when its idling high open the hood and pull the arm on the tb to the idle position and see if it moves. no vacuum leaks? egr ok?
