Engine does not fire until fuse is replaced.
Old Feb 10, 2011 | 02:46 PM
Chevy33's Avatar
Default Engine does not fire until fuse is replaced.
1998 2.8L Fuse is located on the passenger side up front just beside battery. There are two fuses and the one closest to the rear of the car was a twenty but a 30 does not blow. What is this fuse for? The engine runs extremely rough. Distributor was set to # 1. no adjustment is getting it to run smooth. Idle is rough and back firing when throttled. Plug wires are correct. Seems like it is not advancing spark.
Old Feb 10, 2011 | 06:59 PM
is this a 98 camaro?
Old Feb 11, 2011 | 03:49 PM
The reason fuses blow is because the circuit is overloaded. Putting in a bigger fuse does not fix the overload, but will allow the wires to overheat and possibling go on fire. Get a wiring diagram and chase the overload down.
Old Feb 11, 2011 | 05:16 PM
Chevy33's Avatar
This is my bosses car a 98 body with a 94 motor and computer.
My boss is a mechanic and he gave up on it. He wanted me to pull the motor. I checked the compression and all cylinders are good. Fuel is delivered too. I could not see pulling the motor when it fires and it ran well enough to circle the shop. Idle was rough. I figure if the motor turns over and it is not banging or grinding the problem lies in the distributor and ecm. As for the fuse I would like to know first what rated fuse is the correct one.
Old Feb 11, 2011 | 05:41 PM
BasicConcepts's Avatar
Technical User
2.8L im lost there is no 2.8L 94 engine it was a 3.4 which has no distributor or a LT1 350 either way your posting in the 3rd gen section which is 82-92 era cars
Old Feb 11, 2011 | 06:09 PM
i didnt think a obd1 wiring system was compatible with the obd2. what all has been changed? i would like to see a picture of the motor, then maybe we could figure out what it is.
Old Feb 11, 2011 | 08:36 PM
Chevy33's Avatar
My mistake this must be an 89. My apologies. The motor clearly says on it that it is a 2.8L. I've looked at the body styles and this is a third gen.
Old Feb 11, 2011 | 08:45 PM
Technical User
ok yes there was a 2.8 in the 3rd gen cars 89 does sound better
im gunna go with z28pete and say you need a diagram something is wrong with the wiring and deff DONT put larger fuses in that can very well cause fires
Old Feb 11, 2011 | 08:47 PM
Chevy33's Avatar
Here is the motor. http://www.google.com/imgres?imgurl=...refurl=http://[IMG]www.cardomain.com/ride/3830022/1986-chevrolet-camaro&usg=__-gIAFaZHkuIQTYRqGDS0AQYelYU=&h=480&w=640&sz[/IMG]
Old Feb 11, 2011 | 08:50 PM
Technical User
thats just a link to google
