egr
Old May 23, 2007 | 07:19 PM
350rs's Avatar
March 2008 ROTM
Default egr
yea, mines not working, thinking it MAY be a vaccume leak somewhere... but where? maybe a broken line? if so, can i just use a piece of correct fitting rubber hose to fix it? or would it collapse? like a fuel line or something?
Old May 24, 2007 | 12:35 AM
ohiocopper12's Avatar
Default RE: egr
my friend said to take a 1/8 piece of steel, drill 2 holes and seal the hole where the egr goes and get rid of the darn thing altogether. sorry, not a lot of help to you. mark
Old May 24, 2007 | 02:00 AM
MadMikeZ28's Avatar
Default RE: egr
Follow the line to the solenoid and check them and the vacuum source. Push up on the diaphram and plug the line on the egr with a finger and see if the diaphram comes down or holds vacuum and stays. If it comes down its bad. Check the solenoid connection and power to the pink wire.
Old May 24, 2007 | 07:28 AM
350rs's Avatar
March 2008 ROTM
Default RE: egr
yea, we checked it all last night, workin fine. We even pushed the diaphram a bit to see if the passage is clogged or something, it bogged down just like its supposed to. So im still in a loss here, i have no idea whats wrong with it.
Old May 27, 2007 | 08:14 PM
350rs's Avatar
March 2008 ROTM
Default RE: egr
anybody happen to have a ballpark guess as to how much one of these cost? new
