Door window trim
Old Oct 6, 2008 | 08:04 PM
kyleag89's Avatar
Default Door window trim
My 86 Z has dryrotted window trim. The trim that goes against the glass and keeps water from entering the inside of the door and rotting. My question is where can I find these and how much of a pain is it to install? Also where could i find the clips that go on the trim above the doors? I replaced my headliner and broke these clips.
Old Oct 6, 2008 | 08:26 PM
TjD's Avatar
TjD
Default RE: Door window trim
i like hawksthridgenparts.com alot but you can get about anything cheap via e-bay
Old Oct 6, 2008 | 09:35 PM
MadMikeZ28's Avatar
1aauto.com has all types of weather strips and molding. And in a pinch you can use door panel clips on the trim around the windshield/door. Might have to trim off some of the round end to fit in the rectangled slot. Also you would not want them to fit real tight in the slots because if you had to remove it again you run a chance of breaking the lip on the slot in the trim.
rockinjohnny
Apr 13, 2013 11:03 AM
FosterW
Oct 12, 2011 08:26 PM
bns454
Mar 16, 2010 06:33 AM
McGnrAcDcfan227
Jan 12, 2010 05:19 PM
nortonm
Mar 4, 2009 11:37 AM
