dies out at half throttle
Old Jun 15, 2011 | 05:43 PM
  #21
4g63t's Avatar
i do have two connectors all the way up and to the right(drivers side) thats not connected to anything
Old Jun 15, 2011 | 06:08 PM
  #22
microkid's Avatar
March 2011 ROTM
Technical User
can you take pictures of those connectors? take a look around to make sure there are no missing or unplugged sensors. the one back there is probably for the tach. a missing tach signal will mess up the ecm. there are though unused connectors. and only one fpr
Old Jun 15, 2011 | 06:14 PM
  #23
4g63t's Avatar
okk
and im talking about these two
im pretty sure my tach is plugged in it just doesnt work because it would be at 0 ill start is and it would jump all the way past redline
Old Jun 15, 2011 | 06:30 PM
  #24
microkid's Avatar
March 2011 ROTM
Technical User
ah, alright. one of those is the hot feed to test the fuel pump. not sure on the other, kinda hard to see. does the check engine light illuminate when you turn the key on? if not, try to find someone who will check the codes on it
Old Jun 16, 2011 | 11:24 AM
  #25
4g63t's Avatar
yea the last time i did that the CEL stayed on and never went off, but when i start it it doesnt stay on
Old Jun 16, 2011 | 06:35 PM
  #26
microkid's Avatar
March 2011 ROTM
Technical User
the code will still be stored. it will be a bit tough to find someone who can read the code, but you can do the blink test. search for the procedure, then let us know what you come up with
Old Jun 16, 2011 | 10:08 PM
  #27
4g63t's Avatar
ok so i just found out that theres a bad batch of gas going around here in CT one dealership reported servicing over 15 cars with fuel injection issues and sevrel independent shops
how can i manually check injetors
txcamarogirl
Oct 1, 2012 09:22 PM
2nd gen year 78'
70-81 V8 Tech
Aug 31, 2009 02:30 PM
