dies out at half throttle
Yeah, well that's not your transmission then. Thinking that your fuel supply might not be keeping up with demand as the throttle opens would be a logical "first guess". You'll want to hook up a fuel pressure gauge to your fuel rail to see what's going on, or maybe going down. Also, find the vacuum hose that's connected to the fuel pressure regulator (mounted on the fuel rail). Pull the hose and see if there is any fuel in there, if so, then it's bad.
i know what all those thing are.
but what i dont know is where in these cars it is ( fuel rail)
i just orded a inline fuel filter
Don't install a (non-original placement) in-line filter, you're dealing with a high pressure fuel line. Replace the factory filter, it's located near the rear drivers side frame, in front of the rear tire.
Good, that's a factory replacement filter. When you said an in-line filter, I pictured you grabbing one of those universal types off the shelf.
You might get lucky and find your existing filter is dirty and restricted.
thats what im hoping
