Codes for 1991 RS with paper clip trick
Does anyone know where I can find these codes that is flashed by the service engine soon light, when you use a paper clip on computer hookup. I know how to read it ... I just want a more in-depth code list than the Haynes manual lists.
Thanks,
Z3R0
Thanks,
Z3R0
MOST places will give you exactly what the haynes tells you. however, some places will tell you a few things to try that are common to cause the problem. What are they? your guess is as good as mine, like ******* said, google is your friend, in this case for sure.
JTNKTZ
07-13-2008 09:57 AM
JTNKTZ
07-12-2008 11:31 AM
