is it the chills or wat
Old Jun 12, 2010 | 08:26 PM
silamianos's Avatar
Default is it the chills or wat
hey guys my name is josh I have a 1986 chevrolet camaro with a 2.8L V6 (yes i intead on replacing it with a V8) with a th700r4 automatic transmission. The engine is brand new and the transmission has had some work done at my local aamco shop but now it is shaking like crazy worse than my dads modified harley i thought it might b the u-joints from reading about them but i just replaced them and its still happening. i was wondering if anybody new wat might b my problem other than i have the crappiest engine ever. thanks
Old Jun 12, 2010 | 08:52 PM
explain a little better. is it shaking or vibrating? does it do it all the time or when the cars moving, if moving what speed and does it change with speed or rpms? if you take it out of gear or slow down does it get worse, better or stay the same. were can you feel it, steering wheel, shifter, gas peddle/brake peddle, seat of pants?
Old Jun 13, 2010 | 12:01 AM
silamianos's Avatar
the entire car is shaking and it is worst at about 1000 rpms when it is in park or neutral when i shift into reverse drive 2nd or 1st it stops then when i start driving again it gets to 1000 rpms and it is horrible then as the rpms get higher it gets better then when i slow down it gets worse and worser its like i have harley davidson idling at like 200 rpms
Old Jun 13, 2010 | 06:01 AM
ScottD's Avatar
Unhappy
worser?
Old Jun 13, 2010 | 06:26 AM
if its doing it when the car is not moving then its not in the drive train. was it doing it after you got the car back from ammco? could be the torque converter is out of balance, a couple plug wires are crossed to the wrong place, maybe one plugwire is arking and causing a misfire.
Old Jun 13, 2010 | 04:32 PM
I'm lost. Here, take these and use em: . . . . . . . . .
