changing a Fuel injected car to carbureted
i was looking around on here for information as to what i can do about the fuel system for my car that im changing from Fuel injected v6 to a carbureted V8. some people said on here to get a Fuel pressure regulator if your going carbed. This may be a dumb question but if i get a fuel pressure regulator, will that decrease the amount of horsepower and gas milege in my car, or should i put in a gas tank from a carbed 3rd gen camaro and a mechanical fuel pump with a new fuel line? any help is aprreciated
RE: changing a Fuel injected car to carbureted
first of all if your going to use the existing tank and fuel pump you will have to get a return style regulator. a standard fuel regulator will not work. carbed fuel pressure is around 5 psi fuel injection is around 50. the right way would be to put another tank and mechanical pump, but it is also the hard way. to remove the tank on a 3 gen you have to drop the exhaust as well as the back rearend support and jack the body til the rear tires are just leaving the ground. can be a pain in the ****. the easier softer way is to use a return style regualtor that will work just as good as long as you don't over pressure the carb. Sick
car, carberator, carburated, carburetor, changing, fuel, gen, info, injected, injection, mechanical, pump, regulator, removal, tank
