changeover
Old Jun 11, 2007 | 12:15 AM
sexyz's Avatar
Default changeover
i am fixing to change my 700r4 in my 87 roc to a t5 transmission. i was needing to know if anyone could tell me what all i need to change and do to make this work.. ANY help is apprecieted.. thanks alot
[hr]
Old Jun 11, 2007 | 10:05 PM
1985RS's Avatar
Default RE: changeover
well you need a t5, bellhousing, clutch, flywheel, clutch/brake pedal assembly, clutch master cylinder, clutch slave cylinder, you will need to cuta hole in the trans tunnel for the shifter, probably a different driveshaft(not 100% on that), probably a new crossmember, thats all i got right now
jcastner
Jun 20, 2012 11:47 AM
06cummins
Aug 3, 2008 10:44 PM
martybaker
May 30, 2008 01:04 AM
