Cat?
The recommended way is to insert a pressure gage in the exaust pipe in the engine side of the cat and compare with the pressure on the exit side of the cat. If it is really plugged off, tha car may be able to run OK at low speed but choke on itself at high speed, only to start runnig OK once it loses enough speed, and repeats the cycle.
whats the point in gutting the thing? if you ever want to pass inspection, you need to have it working. theres no fun in having a camaro with huge REJECTED sticker, trust me....
