Car only revs past 30 mph
Old Dec 4, 2012 | 10:39 AM
RonnieJ86's Avatar
Default Car only revs past 30 mph
so earlier today I was driving around got another nice day, and I was going up this lil hill. I noticed it was starting to go slower since I wasn't on the gas so I went to push it and all it did was rev as if it was in neutral. I went to pull over put it in park and turned it off and started it again. Park, reverse, neural all worked so I put it in drive again. It felt like it was ok I hit the gas and it would go, but once it hit 30 mph nothing all it did was rev up. I looked around a few sites some say to unplug the battery for a few mins and see if that fixes it. Does anyone else have an answer what it could be?
Old Dec 4, 2012 | 11:37 AM
MKCoconuts's Avatar
Does it do this on flat ground or just going up hills?
Old Dec 4, 2012 | 12:00 PM
RonnieJ86's Avatar
its on flat grounds as well
Old Dec 4, 2012 | 12:42 PM
BasicConcepts's Avatar
Technical User
Does it shift to second gear when it slips or is it still in first?
Old Dec 4, 2012 | 12:50 PM
RonnieJ86's Avatar
i think it stayed in first once it got up to 30 it just then reved i never heard it shift
Old Dec 4, 2012 | 12:53 PM
RonnieJ86's Avatar
but also thats from a stop it get to 30 but when i was going slow threw neighborhoods around 10mph and then came out it would go to bout 25 and rev
Old Dec 4, 2012 | 12:56 PM
Technical User
Sounds like the trans is slipping. You can put some Lucas stop slip in there but its just a bandaid and will slip again.
Old Dec 4, 2012 | 01:01 PM
RonnieJ86's Avatar
ok I thought it might been that, I was already planing on getting a upgrade rebuild kit from transmissioncenter.net cause I was gonna do a 350 swap. Do you think doing the rebuild kit now would hurt anything besides my wallet lol.
Old Dec 5, 2012 | 08:58 AM
microkid's Avatar
March 2011 ROTM
Technical User
make sure the tv cable is installed and adjusted. its located on the throttle body near the throttle cable, and has a D-shaped button. make sure its still on the throttle linkage. press the D in (its very hard), slide the plastic end down into it. relase button, open throttle to full and it should adjust correctly
Blake_Camaro00
Apr 29, 2015 08:24 PM
mpr21290
Mar 7, 2015 01:23 PM
4g63t
82-92 V6 Tech
Jun 3, 2011 02:30 PM
imcdowel
Nov 27, 2010 01:14 PM
mgray
82-92 V8 Tech
Jun 13, 2007 02:15 PM
