Car has trouble idle
I got my new motor into my car. Here is a break down. Headers, hi flo cat, edlebrock 3in cat back. Edlebrock intake manifold, smog pump delete. I can drive the car all around no problem. When i come to a stop it will shut off. Any suggestions, also i had really really old gas when i bought the car and then it sat for like another 5 months. Filled up with 93 and gas cleaner new fuel filter also. Have AC Delco standard plugs in now am going to put in bosch P4's in there when i finishing breaking the motor in.
[align=left] [/align]
RE: Car has trouble idle
Some times it will idle in park. It idles around 500-750 then cuts out. I was told but a guy that had a similar problem that his fuel pump was bad and not pumping enough pressure, so i am going to check the pressure at the rail.
Throttle body injection. My plans are new pump, new pump screen/sock, throttle body rebuild kit, bigger injectors from a 350 truck, and replace any piece of vacum line i see. I am checking on the injectors, if my intel is right then 305 TBI camaro's have 40-45PPH and the trucks come with 55PPH.
my car stalled on me last night. i need a throttle cable because it sticks. i shifted into nuetral going into an intersection and tapped the gas to loosen the cable, and it dropped down to like 600 rpm, then stalled.
