can you help tell me what this part is?
Old May 29, 2011 | 09:35 AM
A1bertmarkovski's Avatar
Question can you help tell me what this part is?
i have one part im not sure what it is...
here is what it looks like
also can you tell me where this tube that is cut leads to or goes to or even what it is?
Old May 29, 2011 | 01:50 PM
carguy68ssrs's Avatar
That vac line should go to fuel pressure regulator right underneath manifold and in front of dist. You can see it in your pic, round dome shaped thing with hose fitting sticking up. Other thing looks like map sensor
Old May 29, 2011 | 05:37 PM
What year did were map sensors used?
Old May 29, 2011 | 08:05 PM
I think just about all 3rd gens. Where did you take it off the car from?? On the firewall by the brake booster??
Old May 29, 2011 | 08:16 PM
microkid's Avatar
March 2011 ROTM
Technical User
map sensors were 89 and up only. 85-88 used a maf. the cut vacuum line probably goes to the map sensor. does the car idle high and run like crap?
Old May 29, 2011 | 10:09 PM
yes its idle is real bad and it runs worse than crap if i get it to run at all...but its a 88 camaro...so i dont understand where it came from unless the motor was swapped?
Old May 30, 2011 | 04:05 AM
It looks like your fuel pressure regulator is already hooked up to manifold. The vacuum diagram on hood sticker says that hose is for HVAC. It gives vacuum for heat and air controls
Old May 31, 2011 | 07:15 PM
microkid's Avatar
March 2011 ROTM
Technical User
88 was the switch over year for it to go to a map. the maf is located on the air inlet tube before the throttle body. if you dont see a maf with a 3 wire plug on the inlet, then it is a map car. running it without that sensor and with a vacuum leak like that will cause it to run badly. the map i think is mounted under the upper plenum. my car originally used those two ports for the fpr and the egr. my hvac is on the driver side, but i cant remember if its supposed to be or not. i suggest picking up a chilton's manual, they have an excellant vacuum diagram
Old Jun 3, 2011 | 09:18 PM
Katzen's Avatar
yeah thats a map sensor, when ours went bad the gas went down to 12 mpg and would smoke more than normal, when we changed it it went back up to 22 (it smokes cause the valve seals melted cause we got the wrong kind)
Ecidemon
Sep 3, 2012 04:16 AM
BlueKitsune
Nov 20, 2008 03:44 PM
IROCNeeveeZ28
82-92 V8 Tech
Jan 20, 2008 01:10 PM
evansrs
82-92 V6 Tech
Oct 10, 2007 08:53 PM
