camaro body repair advice needed
Old 10-09-2008, 11:22 AM
Default RE: camaro body repair advice needed
I should have clarified that you don't want to use a conventional drill bit on the spot welds that are on the car now. You can use a regular bit on the replacement core support if you want since the body panel that it's attached to is scrap. There's a special bit that's used for cutting out a spot weld. Using a regular drill bit on the car will leave a hole underneath where the spot weld holes are and give you nothing to weld the replacement panel to. Of course, that's assuming that all the spot weld holes fall in exactly the same place on both the old and new panels. If you don't have a grinder to remove the spot welds, something like this spot weld drill is what I'm referring to.
Spot Weld Bit
Old 10-09-2008, 03:32 PM
MadMikeZ28's Avatar
Yup Spot-Eze were the ones I always used. Except I used give $30 or so to the Mac or Snap-on guys. But they would warrenty them for me
But you can still go through or too deep and thin the metal with those as well. Thats why many times I would just use a stone grinder or cut off wheel and thin the old panel enough where I could peel it and use a soft back grinder to clean up with afterwards.
Old 10-16-2008, 12:06 AM
1989_RALLYSPORT's Avatar
hey thanks for all the help so far..
the core is in the fenders are on an the iroc hoods on too
just gotta get the bumper on
Old 11-13-2008, 06:26 AM
Default RE: camaro body repair advice needed..{finished product photos}
Old 11-13-2008, 11:23 AM
MadMikeZ28's Avatar
Looks like a job well done.
Old 11-13-2008, 12:44 PM
Looks like a job well done!
Old 11-13-2008, 02:30 PM
MadMikeZ28's Avatar
ORIGINAL: Camaro 69
Could not have said it better myself.
Old 11-13-2008, 03:30 PM
Well, you know...some people are just naturally good with words, and some aren't.
Plus, I added a little flair with a (!) at the end.
Not bad for a 7th grader, eh?
Old 11-13-2008, 04:44 PM
MadMikeZ28's Avatar
Not bad at all. But that is expected as you are an upper classman. I am only in grade 6.[8D]
  #20
Old 11-13-2008, 10:12 PM
thanks
now all i need to do is get the rest of that ugly trim off an get the matching ground effects with the vent holes prime it and paint it
good thing im starting school in auto body.... lol we have to bring in a project car to work on for a grade with all supplies paid for...lol so basically i can get my body work done with no cost and i can get the colors i want....lol if only they would supply pearlescent paint but they dont as its nearly 5000 a gallon in the color i want
Quick Reply: camaro body repair advice needed
