cam vacuum isues
Old Sep 16, 2010 | 03:24 PM
black89rs's Avatar
Question cam vacuum isues
i recently refreshed an 88 350 tpi and put a slight cam in it. ever since i put the engine in my brake pedal is hard like it has a vacuum leak. open my oil cap and vacuum is in valve covers as well?? possibly intake???? help by the way the car is an 86 iroc
Old Sep 16, 2010 | 03:28 PM
May want to invest in a vacuum gage and see what you got, and take from there. Vacuum under the valve covers is rather strange, unless the intake side of the PCV system is blocked.
Old Sep 16, 2010 | 03:32 PM
black89rs's Avatar
i got straight vacuum through the pcv. i do need to get a mityvac or something
Old Sep 16, 2010 | 10:36 PM
Before you go that route, you may want to check that the valve clearance is correct, cam and ignition timing is correct, and for vacuum leaks, as any of those can result in low vacuum. You mentioned the cam is fairly mild, so that should not cause your problem.
Old Sep 17, 2010 | 01:08 PM
black89rs's Avatar
thanx man that makes sense. when i put the engie in i didnt adjust valves
Old Sep 20, 2010 | 06:19 PM
black89rs's Avatar
adjusted valves seems to help with issue.. put in a breather element filler cap.
Old Oct 3, 2010 | 08:54 PM
FSTKMARO's Avatar
What size cam did you put in? A radical cam will affect the vacuum and you will need a reservoir.
I had a 86 cutlass that I put a 400 SB in it with a radical cam. The brake pedal was hard as a rock until I put a reservoir in it for vacuum. It helped as it allowed you a couple of brake presses before turning hard again. It would soften after building some vacuum.
I am sure it is your cam, sometimes degreeing the cam will help greately.
I hope this helps.
Old Oct 4, 2010 | 09:45 PM
black89rs's Avatar
thanx kmaro but i found out i have bigger issues, low compression. only running 54 psi. before wet test. did not do wet test figured no need
Old Oct 5, 2010 | 08:35 PM
microkid's Avatar
March 2011 ROTM
Technical User
try the wet test while youre at it. if it doesnt change the reading, then your vavle are misadjusted (if you arent burning coolant or having bubbles in the rad)
jcase350
82-92 V8 Tech
May 16, 2012 11:40 AM
kyles_81camaro
Apr 13, 2011 03:48 PM
twdavis61@comcast.net
May 14, 2009 06:34 AM
hipirn
Dec 5, 2007 09:36 PM
95camz28
Nov 12, 2007 08:17 PM
