buying an 85 Z28
Old Nov 16, 2010 | 01:50 PM
cherry-m3's Avatar
Default buying an 85 Z28
Before i buy the car i just want to ask the forum of you opinion on the car.
Its an 85 z28 white with black interior,
16IN BBS RIMS/COOPER 255/45 16 TIRES
1982 FIBERGLASS HOOD
NEW PAINT
2 SETS OF T-TOPS
355 CU IN MOTOR 4 BOLT MAIN 10.5 TO 1 COMP. RATIO
OIL COOLER
EDELBROCK TPI FUEL INJECTION 1000CFM
PORTED/POLISHED CAST IRON HEADS 1.6/2.2
3IN BORLA HEADERS/EXAUST WITH CROME TIPS
EDLEBROCK VALVETRAIN
700R4 AUTO WITH B&M REBUILD AND SHIFT KIT
B&M TRANSMISSION COOLER
3.42:1 POSI WITH 33 SPLINE AXLES
UPGRADED COMPUTER CHIP
4 CORE RADIATOR
DUAL COOLING FANS
NEW STEERING BOX
4 WHEEL DISK BRAKES
HOTCHKISS SUSPENSION FRAME CONNECTORS
NEW COOLING/HEATING FAN
NEW WEATHERSTRIPING
POWER WINDOWS
NEW CARPET
MOMO STEERING WHEEL
NEW HEADLINER
ROCKFORD SPEAKERS/AIWA HEAD UNIT
I saw the car and the body seems to be in good condition (paint had a few scratches here and there, but overall normal wear and tear). The "bbs" wheels are really ta wheels powdercoated black. Another thing is upon inspection of the engine bay, i saw that the bottom of the block by the headers had some oil so i think the vlave cover gaskets might be leaking but not exactly sure. It has been repainted, and the car origionally had roll up windows. Any input would be greatly apppreciated
Old Nov 16, 2010 | 02:24 PM
djs383's Avatar
Whats the price?
Old Nov 16, 2010 | 03:04 PM
cherry-m3's Avatar
I would be getting it for 1600
Old Nov 16, 2010 | 03:54 PM
cherry-m3's Avatar
I forgot to add that the right front and rear turn signal does not work (not sure if its the bulb, but seems electrical). The positive battery terminal wire might need to be replaced also.
Old Nov 17, 2010 | 08:35 AM
GLENN M's Avatar
does it still run,if it has all those parts and isnt knocking making any clunking sounds its definetly worth the price.if you dont no how to evaluate motor trans condition get someone who does if ok buy it !
Old Nov 17, 2010 | 01:37 PM
cherry-m3's Avatar
the car runs, and starts right up. Dint hear any knock, but only thing i noticed is that it had a slightly rough idle. As for the engine it was a crate i believe that was ordered online and has about 25-30k on it.
Old Nov 17, 2010 | 08:59 PM
big greg's Avatar
shoot sounds like its worth about 3500$ i would have already bought it!
Old Nov 17, 2010 | 11:19 PM
GLENN M's Avatar
for 1600 your getting hell of a deal,idle probly rough because of valve train and cam,normal for go fast items you described
Old Nov 18, 2010 | 05:25 PM
ScottD's Avatar
JUMP ON IT! JUMP! NOW! I dont even wanna tell you what that car would fetch up here!
Old Nov 18, 2010 | 06:15 PM
microkid's Avatar
March 2011 ROTM
Technical User
go for it, it sounds like its worth it to me. the engine and intake peices alone are over $3000
