backspacing
Old Aug 21, 2009 | 07:43 PM
  #21
Mesosneaky's Avatar
ya just was looking to get some tires lol. Inspection is in october and I need to get some new ones to pass that. figure I would try to learn what rims would fit just incase I found another deal like that.
Old Aug 21, 2009 | 07:48 PM
  #22
I know sneaky was primarily looking for tires. But when he brought up the Weldstars, it made me remember this:
http://2loose.chevytalk.org/weldrims.html
Old Aug 21, 2009 | 08:02 PM
  #23
Stix80's Avatar
wow that would suck
Old Aug 21, 2009 | 08:03 PM
  #24
Mesosneaky's Avatar
wow that is pretty crazy.
Old Aug 21, 2009 | 08:06 PM
  #25
Stix80's Avatar
hey sneaky what size tires were you looking for
Old Aug 21, 2009 | 08:13 PM
  #26
Mesosneaky's Avatar
I'll have to check I dont know what I have on them right now. I'll post them tomorrow. I'm putting the edelbrock preformer intake,accel distributor, b&m kickdown cable, and the new carb gasket i just got to free some heat from the carb. http://www.summitracing.com/parts/EDL-9266/
Also got some new 3inch headers. So im trying to find 3inch ypipe.
You connect the distributor to the left side of the carb vacuum correct? why do you do this? thanks.
Old Aug 21, 2009 | 09:21 PM
  #27
Mesosneaky's Avatar
Hears the headers I got. They look great who knows how long they will look that way tho. Welds seem like they could of been nicer. But you get what you pay for. Overall im happy with the just hope they will go on without and clearance trouble. 3 inch collectors. I'm thinking about getting the hooker y pipe with the 3inch inlet 2.5inch outlet. Which also bypasses the cat.
Old Aug 21, 2009 | 09:39 PM
  #28
microkid's Avatar
March 2011 ROTM
Technical User
you would be better off getting reducers from the heads going into a 2.5 inch pipe, then merging into a 3 inch single pipe. if you can get someone to pass it without a cat, thats cool. if not, run a pipe through the cat. i did that with my blazer. passes visual, and i dont need emissions
Old Aug 21, 2009 | 09:45 PM
  #29
Mesosneaky's Avatar
http://www.summitracing.com/parts/HOK-16767HKR/
this is the y-pipe I want to get it bypasses the cat. 3inlet/2.5 outlet.
The headers came with 2.5 reducers though if need be.
But that y pipe looks to go straight up and the headers look to be more of a slant \ .
Anything to share with that? Are these headers not compatible?
Old Aug 21, 2009 | 09:53 PM
  #30
microkid's Avatar
March 2011 ROTM
Technical User
yea, it may not work. says theyre designed to work with hooker headers, idk what brand your headers are. anf for $250, you can have a shop custom make a header back exhaust and weld it all together for you. i think the header companies design them that way you can only use their y-pipe with their headers
