auto to five speed swap
it will be a weekend project or longer. need to remove old tranny brake pedal and cut a hole in the tunnel. it sound easy but it is time consuming. if you go through with it good luck.
3rd gens weren't ever column shift, only tunnel shift. you're going to need EVERYTHING for the T5. new clutch and pressure plate, clutch fluid resevoir, new pedal assembly, new trans mounts. it's going to be a lot of work, i can tell you that one right now
