ATTN!!!!! 350RS PLEASE READ
About that forum that you posted asking if it was possible to make a 350 to a 396, i have good news for you, not many people know, but i was talking to a machinest in my local areaand he said that it is possible to bore it out to a 396 with the cylinder walls being of the same diameter but it obviously won't be a big block like every other 396 out there, i had plans on doing that to my small block was it was justa little bit more than i could afford at the time, but i was told that it is deffinetly possible.
RE: ATTN!!!!! 350RS PLEASE READ
sweet action, thats what i like to hear!! Ill talk to some people around here and see what they would ask for it and what i would need to be as far as cranks and piston diameters. Thanks!
With a .060 over and a 400 crank turned to fit into the 350you will get 388 ci. You want anything bigger you have to go with 400 block or a bow tie block with siamesed cylinders. You can make a 4.150 bore with those. Cylinder walls are too thin to go over .60 in a production block
ORIGINAL: MadMikeZ28
ORIGINAL: zerokool91
What in the hell is siamesed cylinders?
The cylinders are connected where there are no water jackets between them. It allows them to be thicker so they can be bored bigger.
go to www.strokerkits.com/sbc_forged.htm . it has a 3.875 stroke with a 6in rod and only needs to be bored 30 over. sell's for $1380 on this website. kit # 1-40900-1. hope this was some help for you.
