Aftermarket Chips
Old Apr 16, 2008 | 06:28 PM
camarohelp's Avatar
Default Aftermarket Chips
So, after months and months of VATS trouble, I finally found that the VATS bypass can be a two part job. In my casebypassing the PROM in the ECU wasn't enough - I had to permanently enable the crank enable relay.
I'm proud to say my car runs perfectly now (for a 16 year old car).
There is, however, one new problem. The bypass we were sent came with a 110mph speed limiter which we didn't order. Rather than send it back and wait for a replacement, a friend of mine with his own camaro suggested I get an entirely new performance ECU. He promised me the usual "noticeable difference."
What do you guys think? Has anyone come accross a chip that actually increases performance in a stock camaro?
1992 Z28 305 w/manual.
Thanks!
Old Apr 16, 2008 | 06:39 PM
blackz87's Avatar
Default RE: Aftermarket Chips
Some chips on a stock motor just change minor items and really don't add performance,but they do make a small difference. Just don't expect a 305 tbi to turn into a fire breathing 350.
Old Apr 16, 2008 | 06:41 PM
SpecterGT260's Avatar
Ninja Administrator
not ona stock car, and then even if you are doing it to a very modified car you are playing russian roulette with ur motor.you dont know if that tune is good for you. strap that car on a dyno for basically the same cost as any of these chips.
i personally dont trust mail order stuff, i like to see the AFR curves for myself
Old Apr 17, 2008 | 04:37 PM
camarohelp's Avatar
I guess there really are no free lunches.
Old Apr 17, 2008 | 10:34 PM
brassknukl's Avatar
you can find a free lunch in any dumpster you see.
its where most of them "performance" chips end up maybe you can find one of them too.
Old Apr 17, 2008 | 10:56 PM
MusicMan's Avatar
The Jazz Man
Yeah, those chips don't do much good at all, if any.
Steve y87
Mar 18, 2012 07:55 PM
hoppinchevy
Feb 21, 2010 08:23 PM
bluovlh8er
Sep 7, 2007 08:52 PM
bumpnbrd2005
Jan 2, 2007 04:44 PM
CaMaRoDuDe
Sep 22, 2006 12:09 AM
