92 gauge cluster
Old Apr 23, 2008 | 11:27 AM
brad87's Avatar
Default 92 gauge cluster
i'm looking at buying a 86 z28, I used to own a 92 rs. In my opionon the gauge cluster in the 91 and 92 is alot nicer than the ones in the 86. does anyone know how hard it would be, if even possible, to put a 92 gauge cluster in a 86?
Brad
Old Apr 23, 2008 | 11:37 AM
blackz87's Avatar
Default RE: 92 gauge cluster
For one the 86 has mechancial speedo and the 92 is elecctric. Unless you don't care about the speedometer go ahead it will fit.
Old Apr 23, 2008 | 03:18 PM
MadMikeZ28's Avatar
You can get a unit that sends an digital signal to the speedo and it screws onto the tranny where the cable is. But what is wrong with the cluster I had in my 84? You can not fit it into a 90-92.
Old Apr 23, 2008 | 11:02 PM
brad87's Avatar
wow i really like that, where did you get it, or did you make it yourself?
Old Apr 24, 2008 | 11:06 AM
MadMikeZ28's Avatar
The panel is from Covan's classics. (don't be fooled, its abs plastic) The gauges I had purchased from Summitracing.com (you can get the whole panel with gauges. I just had the gauges for years before) I had put in two small green LEDs for signal indicators and the yellow light was my check engine light I mounted under the center vents. I also had to get a custom made two piece speedo cable and a hall effect untit because on the back of the OEM cluster there is a VSS.
Old Apr 25, 2008 | 10:11 PM
CCarRocks's Avatar
So just a re-cap.
Will a guage cluster from a 90-92 fit into the panel of say an 86. I have a new one with 0 miles on it that is the 145 MPH speedo.The originalin the car nowis acting up so I thought about installing the newer one.
I too like the newer gage faces.
I'm good with having to change the speed sensor or what ever else so long as its not a real big pain.
My buddy has a choo choo conversion El Camino & his speedo is a 220 MPH from what I belive is out of a Covette.
Is that doable also?
Later,
CCarRocks
Old Apr 25, 2008 | 10:42 PM
MadMikeZ28's Avatar
ORIGINAL: CCarRocks
So just a re-cap.
Later,
CCarRocks
The dash in the 90-92 was all reshaped. Even the pad is different. The clusters may fit into the hole but the trim bezels will not match up correctly and may look dorky. Is the 145mphgauge cluster you have for a 90-92? If so and you ever want to sell it let me know.
Old Apr 26, 2008 | 10:37 PM
CCarRocks's Avatar
They are the later model gage set. If I can figure out how to get a photo of them in here I'll post it.
I guess since it would look dorky ( who wants that) I may do something like the gage set in the earlier post.
SoCal68
Oct 15, 2010 06:58 AM
luciora
Apr 23, 2010 04:21 PM
BigRegUK
Sep 14, 2009 03:44 PM
bd92rs
Apr 2, 2009 07:54 PM
19 camaro 84
Jun 19, 2008 08:29 PM
