92 Camaro Question....Please help!
Hey I have a 1992 z28 Camaro. Just recently when I turned my wipers on they would not shut off. The only way they did shut off is when I turned the car off. I changed the switch but it did not fix the problem. Has anyone every had this happen and how do you fix it?? Thanks for the help.
most likely it has been hard wired. while the wipers are on with the car running try pulling out the fuse. If that does nothing then it has been hard wired.
If it was me i would either try to find wire they running it and put a switch on it so you can turn it on and off. the problem with that is you will only have one speed.
although i could be completely wrong i have seen this in two cars that i have bought and also a friends. hopefully it helps
