92 camaro
Old Oct 31, 2007 | 08:55 PM
FURIOUSLCC's Avatar
Default 92 camaro
hey guysso i have a 92 camaro rs 3.1 ltr should i try and fix it up or just swap it out for a 350 but if i do that would i have to swap everything else out like rear end suspension and all that
Old Oct 31, 2007 | 10:11 PM
CCarRocks's Avatar
Default RE: 92 camaro
You will need to change the front springs for sure. The engine controll will have to be upgraded to one correct for an 8 cylinder, more than likely the rear will need to be upgraded also but don't quote me on that one. I'm taking a 90 RS with a V6 in it I just picked up tonight & installing a newly built 383 stroker with carb setup. I have no idea what its' going to take. Hopefully there are friends on this site that will offer there tipsfor doing this. Anything I learn will be posted so keep your eye's tuned. I have a post started about it titled "Try this one". Good luck & let me know what you run into.
CCarRocks
Old Nov 4, 2007 | 12:52 AM
Dougs1990rs's Avatar
first off what are you planning to do with your car? the rearend will hold any power you put to it as long as you run street tire's. you can put a 350 in it. fuel pump has to be removed or spend the money on a good adjustable fuel pressur reglator. snice it's a six cylinder you need to put in a after market tach.
