91 convert Z28 350 Temp idle issues Please read
whatever is going bad is getting worse. you need to check fuel pressure. it could be several different things. throttle position sensor, maf, map, fuel pump, fuel pressure regulator, ignition control modual, weak coil, plugged air filter.
