89 v6 to lt1 swap??
Old 02-17-2012 | 07:25 PM
smbigfoot's Avatar
Default 89 v6 to lt1 swap??
so i just bought an 89 camaro rs, but has the 2.8 v6, been thinking about doing a lt1 swap but need to know if this engine is computerized, and would need to swap over the computer, my 89 has the 700r4 and i do know i need to change the bell housing and torque converter, just need some ideas/help on this swap thanks!!
Old 02-17-2012 | 11:13 PM
iLL95's Avatar
I Like to Party
Super Member
I recommend making a thread in the 3rg generation section rather than the new members section. Welcome to the forums
Old 02-17-2012 | 11:25 PM
BasicConcepts's Avatar
Technical User
yes the lt1 has a computer and you do need it along with the whole wiring harness
the 700r4 is the same trans as the 4l60e (except the e part that electric) but your 700 wont work with the lt1 because its mechanical not electric so it wont shift right (if at all)
Old 02-18-2012 | 06:04 AM
smbigfoot's Avatar
Now what if i did a 350 tuned port injection swap? Would that be an easier/less confusing swap? And would it be a better match for my 700r4??
Old 02-18-2012 | 10:38 AM
i have a 700r4 and lt1 in my 93. you can switch the lt1 to a carb and old school distributor. if you can find a 93 lt1 and trans with the computer and harness. it can be made to work. thing is the 93 was used in allot of builds because it has the 700r4 that is compatible with non electronic systems. so not allot of them out there.
Old 02-18-2012 | 11:09 AM
smbigfoot's Avatar
I had found an 95 lt1 that a guy is selling and was going to go look at it sometime this weekend, the motor, wiring harness, headers and tge y pipe for a good price,
Old 02-18-2012 | 11:33 AM
the motor can be made to work, easier to carb it. you need to do some research on the install.
http://www.thirdgen.org/techboard/lt...questions.html
Old 02-18-2012 | 01:05 PM
Install a carb style intake manifold: LT1 Carb Intake, add a carb, fuel pressure regulator, drop in a conventional distributor, and the engine is ready to go with no computer needed. Bolt on a 700R4 with the appropriate carb linkage for the TV cable, and you're pretty close to having it on the road.
It has been awhile but I am pretty sure the 89 700R4 does not have a "bell housing" it is a one pc tranny. So no matter what that would need replaced, Also GM configures all of its transmission based on the application. So a 700R4 sitting behind a L98 V8 will have differents clutch pack and even gears sets then one sitting behind a V6. So what I am saying is that even IF your 700R4 tranny had a bell housing it would last about 10 minutes behind a 300 hp LT1 because it was configured to deal with 146hp.
I am not sure why no one mentioned the motor mounts, your going to have to modify the motor mounts, SBC mount are a little different.
If you can find a V8 700R4 most of them came from car with less then 200hp so the stock ones will not hold up long. During a normal rebuild it is easy to upgrade the tranny to handle a stock LT1.
The fuel system will need swapped. The v6 fuel pump and lines are nowhere near big enough and for some reason I am thinking the 2.8 was a 60 PSI system but I have not worked on one for 20+ years.
Old 02-18-2012 | 03:54 PM
smbigfoot's Avatar
Ok, so if i get a 700r4 off of a z28, beef it up a little to handle the lt1 and modify the fuel line/pump it should be ok? What about the wiring harness?? Would i have to have a stand alone computer for the lt1??
Quick Reply: 89 v6 to lt1 swap??
