'89 Steering column
So my '89 IROC has a busted up steering column. I can get a good deal on a nice column from a '91 Camaro but will it work??
I realize I can't use the airbag stuff but will everything else bolt up including the blinker wiring ect??
The air bag column is different. your steering wheel will not fit. I am guessing your column is moving around a lot. Its not busted. On tilt coulmns there are screws that come loose and can be tightened.
ORIGINAL: MadMikeZ28
It's busted. As in some idiot tried to steal the car not knowing about the VATs and busted up the column for no good reason.
I don't care about steering wheels. I'm asking if the column will bolt in and work the signals and highbeams without some stupid Chevy year to year "upgrade" that makes the change impossible.
The column I'm looking at already has a non airbag wheel that fits
I can't say for sure because on that rare occasion there is a different multi function or wiper switch. I know I have had to change them before when I would get a wrecking yard column.
Here is what you do. Look up the part numbers for the switches online at autozone.com or napa and compare them. If they are the same then they will work.
