89 camaro problems
89 camaro problems
uncle worked on car was changing freeze plug forgot to plug in the oil pressure sensor back in started car just fine turned off car plugged plug back in car wont start since then changed out oil pressure sensor and the computer the car will start and run fine then after you shut it off it wont start back up for about 20 min losing hope here need help
