89 camaro only starts when choke light flashes on then goes off
1 Attachment(s)
89 camaro my car want start when choke light stays on.when it flashes on and then off it will start right up it has a 305 tbi lo3 motor thangs for any help
Did you do any more follow up to what I suggested in your other same topic thread from back in November? https://camaroforums.com/forum/82-92...e-light-79464/
I missed your last question there, but yes it could be the alternator, or a related wiring issue, or the battery. |
has new battery dont no nothing about checking wireing does it have a choke relay or heater. car will shut off when lights on when i pull the battery cable off
Originally Posted by michael1980
(Post 708149)
Btw, yanking the positive battery terminal was a good and easy way to check on old school cars, but on modern cars that have a lot of electronic controls or devices, doing that can cause a voltage spike without the battery connected to act like a buffer. |
thanks but the car will start when the choke light comes on then goes off .if the light stays on car will not start it has a aftermarket distrubator also half to what may take 30 min or so of trying to make light come on then off
I don't know how to be more direct than I've already been, you have a charging system issue. The choke light isn't the problem, it's a symptom.
thanks but i have no ideal were to start checking were would you start thanks
If you don't have one, pick up a test meter. Then....
my car want turn off with key had ignition switch checked good the people who checked it put a toggle switch to ignition fuse in fuse box to turn car off
