88 camaro 5.0 tpi overheating
Old Feb 19, 2014 | 09:26 PM
Phoenix bird's Avatar
Default 88 camaro 5.0 tpi overheating
This car keeps boiling over and overheating. I replaced radiator and cap thermostat and housing flush radiator . Fans work properly there's no water in the oil so I don't know why it's overheating the upper radiator hose get really stiff when it's got and I just replaced thermostat please help someone who knows these cars better
Old Feb 20, 2014 | 07:57 AM
Everett#2390's Avatar
Pull spark plugs and inspect them.
The cleanest one would be a tale-tale sign of a leaky compression gases into the coolant system, since upper hose is really tight.
Old Feb 20, 2014 | 10:20 AM
When does it overheat...in traffic, out on the highway, or both? If only out on the highway, then look underneath the front of the car for the air dam. It's a piece of plastic that's angled like a spoiler, which directs air up and through the radiator. If that's missing, your engine will run hot when on the open road, just the fan isn't enough.
Old Feb 25, 2014 | 02:09 AM
so if there's a clean speak plug that's a bad sign what should I do then?
Old Feb 25, 2014 | 02:10 AM
Yea it has the plastic under there and it overheats either parked or driving.
Old Feb 25, 2014 | 01:49 PM
Check your ignition timing. Too far retarded or advanced can make the engine run too hot.
Mattroy8812
Jun 13, 2012 01:21 AM
Ziarothe
Aug 19, 2011 02:16 AM
KEVIN LAMB
Oct 21, 2009 10:30 PM
terryst
Sep 6, 2008 12:14 PM
matthew9440
82-92 V6 Tech
May 16, 2008 05:06 PM
