86 Iroc-z
Old Mar 11, 2006 | 02:48 AM
KingJames's Avatar
Default 86 Iroc-z
Got my car going strong, real strong, but she is a dog
she's fast, but I can tell it has the smaller cam and stuff in it
it redlines at 5,000 RPM
the 305 has 88,500 miles on it
I'm going for fast/worth more money
I've been told that keeping the original 305 in it, would make it worth more to a collector, and keeping it yellow would help make it worth more
so I am stuck between getting a 350 for it, or keeping my 305
my cash is limited to around 2 - 3 grand
if I keep the 305 in it, I want it done up as much as possible
I just wanna know everything I can do to this car to make it better, I'm working on getting photos of it for you guys to see what i mean, she's nice, the perfect project car that doesn't need much.
I am proally gonna start with the exhaust, and then get the motor / tranny done, then the rear end
I also been thinking of having the under carriage lined over at line-x -- would it be worth it?
then to the paint shop, I made an appointment, and he says he can paint it by around April 20th, so I have a month to get the motor done and the under carriage lined, if i do have it lined, so I need as much help as possible, only have a month
Old Mar 11, 2006 | 03:36 PM
adrenilinjunki's Avatar
Default RE: 86 Iroc-z
well depending on what you want do do with it if you put in a good 350 it shouldnt hurt the value to much but you can do alot to that 305 start with intake and exaust redo the heads change the cam if its got a carb get rid of the quadra junk and get a holly or a road demon. you can upgrade the ignition system with an accel hei brute thunder coil some aftermarket wires or an msd 6a ignition it will hook up to the stock distribitor. or you could get a msd pro billit distrb. theres tons you can do to that 305 and if you decide to go with a 350 later alot of the stuff will work on the 350 from the 305. dont be afraid to shop around for parts ive saved aton by looking around and ebay has helped alot to.
Old Mar 11, 2006 | 06:24 PM
Pull out the 305 and save for when you want to sell the car. In the meantime put in a good 350 or 383 stroker.
Old Mar 18, 2006 | 12:12 AM
dusty's Avatar
i acually have nice 355 for sale if you want it it has 1.94 heads ported intake long slot roller tip steel rockers screw in studs 2 bolt main umm after market pistons 9:1 compression (great for a blower) umm...the heads are acually getting re done right now no intake or carb it has timming gears so its very acurate a a 540 lift comp cam and comp race springs in the heads great motor about 1200 for the motor and ill put it back together with all new felpro gaskets
dusty's Avatar
adam86107
Dec 8, 2011 06:52 AM
Kyric
Mar 24, 2009 04:09 PM
74454bb
82-92 V8 Tech
28
Nov 4, 2008 02:57 AM
JIROCZ
82-92 V8 Tech
11
Aug 26, 2008 04:12 PM
BLACK 89 IROC Z
82-92 V8 Tech
Aug 8, 2008 06:21 AM
