'86 IROC Passenger Window Problem
Old Jun 15, 2024 | 08:55 PM
mikey444's Avatar
Default '86 IROC Passenger Window Problem
Just purchased a nice '86 IROC coupe. Passenger window is up and will go down approximately 3" then stop and I hear grinding noise, like maybe there is something stuck in the the window mechanism gear or missing teeth in same. Obviously, motor works as window will go fully back up. Haven't taken door panel off yet, as I just bought the car 2 days ago. Previous owner told me of the problem, but he never had it fixed. Any ideas ?
Old Jul 16, 2024 | 12:58 PM
salaberrios@msn.com's Avatar
Default Have you found the issue?
Sounds like a gear issue or maybe the motor needs replaced. Forgive me if you already know this but make sure you use on of those panel pry bars to pop the clips out on the panel and maybe buy you a pack to replace the clips. Also, I think it you need to get the window down to get the top panel off/ Also, check out some videos on changing the window motor. Its not complex but also requires drilling out some rivets. Lastly, not sure what condition the door is in, but I would repair everything before putting the panel back on.
Old Jul 16, 2024 | 01:29 PM
mikey444's Avatar
Yeah, I've got a panel clip tool and extra panel clips. Have also watched several videos on how to replace the motor. My problem is going to be how to get the window down to remove the door panel, because right now it will only go down about 3-4 inches with the motor, then stops and grinds.
rusty vango
Feb 12, 2012 09:44 PM
Presto_07
Aug 30, 2007 12:40 PM
whoffman
82-92 V8 Tech
May 6, 2007 09:09 PM
golfballs
Feb 20, 2007 08:55 PM
KJK
Nov 6, 2005 12:17 AM
