700R4 TO TH350 swap questions
Old Jul 1, 2009 | 02:54 PM
1989_RALLYSPORT's Avatar
Default 700R4 TO TH350 swap questions
ok i have a turbo 350 trans out of a 1975 half ton chevy
IT has been rebuilt with a 9 inch tail shaft instead of 6 inch
now what i need is an adapter block to bolt my 700r4 tail housing to the th350 but the adapter has to be 3 inches long to make the th350 the same length as my 700r4 and still use the bar that bolts to my differential housing
where do i find one of these
or do they make a 9 inch tail housing that fits a th350 and has the mounts for the camaros center bar thing
i was hoping to use the 700r4 tail as i wont have to do any spedo work
Old Jul 2, 2009 | 11:38 AM
~~bump~~
Old Jul 2, 2009 | 09:27 PM
.........does anyone know what Im talking about??
Old Jul 2, 2009 | 10:24 PM
Yes, I know what you're talking about. Can't say I've ever seen what you're looking for though. But if anybody has something like that, I should think this guy would: http://www.transmissioncenter.net/
Old Jul 3, 2009 | 08:05 AM
djs383's Avatar
Why the 350? The 700R4 is the same as the 350 but with OD.
Old Jul 3, 2009 | 11:51 AM
Mesosneaky's Avatar
I was wondering the same
Old Jul 3, 2009 | 08:37 PM
because i got a brand new th350 with upgraded clutches and b&m shift kit for a good deal and watched it get built
Old Jul 3, 2009 | 08:48 PM
i dont want to have to fab my own torsion bar so i need either a 9 inch tail housing with the torsion bar mounts or a spacer plate that will allow me to bolt my 6 inch tail housing from the 700r4 to the th350 trans and end up being the proper length
Old Jul 4, 2009 | 06:48 AM
blackz87's Avatar
You are also looking at a new drive shaft, because the stock one will not fit the 350 tanny.
Old Jul 5, 2009 | 10:47 PM
no not a whole driveshaft just a truck driveshaft end on my driveshaft
