500hp
500hp
hey guys i'm new to the forum...just wonderin...i had a 500hp 327 in my s10 but i took it out and putting it in a 86 camaro...what do u think it will run in the quater.i has a turbo 350 behind it and i'm going to put 3.73 in the rear..so give me some estimates...thanx
RE: 500hp
With a 327 you need much bigger gears than 3.73. If the engine produces 500HP as you stated, which can be done, but not easily in an engine of that size, it is going to be low in bottom end torque and has has to rev up close to 8000 RPMto producethatamount of power.
That being said, with 500HP, proper gears, drag slicks, and proper set up,my SWAG meter sez that itshould crank in the low 12's.
