500 + hp SM BLCK 85 Camaro
Old Oct 18, 2009 | 09:15 AM
jbrunner's Avatar
Default 500 + hp SM BLCK 85 Camaro
For Sale...! '85 Camaro pump gas 383 stroker, (500 + h.p. Brodix Track 1 aluminum cylinder heads,full roller motor, {complete Compitions Cams roller valve train (cam, rockers, pushrods, MSD Distributor & 6AL ignition timing gears, lifters)},Holler 750 dbl pmp, Team- G port matched intake, keith black 9.5:1 pistons, splayed & studed mains, bowtie billet main caps, All professionally machined & balanced). Turbo 400 w/ hipster trans brake, w/ 3500 stahl, Moser Ford 9" w/ 31 spline race axles, Auburn Pro Diff posi w/ Torq-line 4.10 gears, adjustable rear race shocks, Hotchkis lower control arms, South Side Machine rear susupension, Lakewood 90:10 front drag struts, Wilwood four piston front brakes system, aftermarket sway bars, twin electric fans, Hooker Super Comp full length headers, REAL 3" dual exhaust w/ 2 chamber Flowmaster mufflers, electric fuel system w/ sumped fuel tank, 8 pt roll cage w/ tied frame. Rear mounted battery (Optima battery w/ external Flaming River cut off switch) Turbo Action Cheetah SCS shifter, Autometer Phantom gauges (Tach w/ shift light, oil press., temp, fuel press w/ isolator), Weld Dragstar rims w/ Mickey Tompson tires, car was repainted ('96 Porche Guards Red) w/ new front clip (front fenders, nose bumper, headlight supports, new Glastek fiberglass cowl induction hood....this car has almost been completely renewed. It needs minor items (seats, rear tires, engine tuning) to finish. motor has zero (0) passes on it and less than 500 miles. Comes with NOS plate system (not installed on car yet) any questions please email @ jmbjr5@hotmail.com $12,000.00 Chicago farwestern suburbs
Attached Thumbnails 500 + hp SM BLCK 85 Camaro-photo.jpg   500 + hp SM BLCK 85 Camaro-camaro6.jpg
Old Oct 18, 2009 | 07:28 PM
microkid's Avatar
March 2011 ROTM
Technical User
would be best if moved to the for sale section
